Luup code for control the led ring on a Fibara Wall plug
Any one that have a working way to control the led ring on a fibaro wall plug
with a luup code?
I want to use it in a Scene for a alarm indication , As ex, When a door is open, The wall plug show me
a red led ring as an alarm.
Hi Hoffan72 !
I’m looking for the exact same information.
Did you finally find a way to control led with luup ?
So far I’ve noticed that : modifying the variable “VariablesSet” in the advanced tab of the device and then saving does the job (instead of modifying the variable in the Device Option tab).
I’ve then tried to modify this variable “VariablesSet” with luup but didn’t succeed. Vera accepts the code but does not update anything in the device, strangely.
It seems that some other folks have faced the same problem here :
[url=http://forum.micasaverde.com/index.php/topic,1937.0.html]http://forum.micasaverde.com/index.php/topic,1937.0.html[/url]
Please let me know if you find a solution ! :slight_smile:
Cheers
bpm10
No i have not find any solutions for this :frowning:
