Hello,
Can anyone confirm if the Reactor reads LUUP code without problems? And if so, if it is possible to change parameters through LUUP. I would like to change the LED colors of my FIBARO Walli, Dimmer and Switch in relation to the current values consumed.
My rule is:
Luup code:
–SW LED OFF
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “ConfiguredVariable”,“12,1b,0”,125)
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “VariablesSet”,“12,1b,0”,125)
–DIMER LED BLUE
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “ConfiguredVariable”,“11,1b,4”,84)
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “VariablesSet”,“11,1b,4”,84)
–WALLI LED BLUE
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “ConfiguredVariable”,“11,1b,4”,98)
luup.variable_set(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “VariablesSet”,“11,1b,4”,98)
Everything is working, except the parameters…
Ty
