Lutron RA2 no implementation message?
I cannot get the Lutron App to work. I have created the devices but they do not work. When testing the “Poll Now” in Advanced I get “No Implementation”
How Can I ping my lutron controller to make sure the vera and the Lutron are talking?
Any help Please?
Is your lutron system working as a standalone system? Which vera/UI are you on?
Also, have you been through this thread on the plugin forum?
http://forum.micasaverde.com/index.php?topic=17772.0
I found it hugely helpful in getting our system integrated.
Yes - I have the lutron software for programming my system - I can use it with my phone - at home. Still trying to figure out how to make it work offsite - I need to get a VPN working for it ( I think )
I am using the Vera 3 controller on U15.
I will look at your link and see if there is something I have not tried.
It seems to me the best thing to do would see if I can telnet into the lutron from the Vera. then when I know they are at least talking to each other I can figure out the rest.
Sending commands does not work.
Thanks - Craig
Yes - that is the guide I used.
Should I be using the Lutron Parent?
