Lua is reloaded every day at the same time: 20h47.
Here are the last lines in the logs:
[code]
03 10/07/13 20:47:53.234 JobHandler_LuaUPnP::Reload: reload Critical 1 m_bCriticalOnly 0 dirty data 1 <0x
06 10/07/13 20:47:53.608 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:
06 10/07/13 20:47:53.609 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:
02 10/07/13 20:47:53.711 ^[[33;1mluup_log:203: RFXtrx: Bad starting message; ignore byte 69^[[0m <0x2ef0a
01 10/07/13 20:47:53.901 ^[[31;1mMongoose XXX-mg_stop1 0xa36fa0 1 2^[[0m <0x2b941000>
01 10/07/13 20:47:55.901 ^[[31;1mMongoose XXX-mg_stop2 0xa36fa0 2 2^[[0m <0x2b941000>
01 10/07/13 20:47:55.902 ^[[31;1mMongoose XXX-mg_stop3 0xa36fa0 2 2^[[0m <0x2b941000>
01 10/07/13 20:47:55.902 ^[[31;1mMongoose XXX-mg_stop4 0xa36fa0 9354664 2^[[0m <0x2b941000>
^[[7;36m2013-10-07 20:47:56 - LuaUPnP Terminated with Exit Code: 250^[[1;00m[/code]
What could be the reason ? Why always at the same time ?
Today, I even force a reload 10 minutes before but it does not avoid the reload.
The standard answer is restart after nightly heal. Below is an example.
http://forum.micasaverde.com/index.php?topic=13688.0
I would also look at potential deadlock or timeouts which will result in restarts.
What’s happening right before that ?
looks like ur RFX plugin is not working properly after the automatic nightly heal and reconfigure of devices.
Nothing special.
I have no scene planed around this time.
I think the RFXtrx warning message occured due to the fact processes are killed. I got it regurlarly when I restart lua. It is not the cause of the reload but a consequence of the unexpect reload.
[quote=“Brientim, post:2, topic:177249”]The standard answer is restart after nightly heal. Below is an example.
I would also look at potential deadlock or timeouts which will result in restarts.[/quote]
Why in my case, the nightly heal runs at 20h47 ?
How is it triggered ? Crontab entry ? How to modify or disable this job ?
I am no more connected to Micasaverde servers. Could it explain a strange time ?
I have no reload when I run firmware 1.5.408. Is it the nightly heal a new “feature” introduced with firmware version 1.5.622 ?
looks like its crontab yes
it get its time from internet so perhaps the time is not set properly or the timezone doesnt match
i have been seeing this nightly heal since i got the vera so i guess it was allways ther for vera 3 lite. i have this vera since the day it came out.
