I realize lua doesn’t have a C type ternary, but since this works:
print('x is ' .. (x < 0 and 'negative' or 'non-negative'))
I thought I could do something like this:
[code]local state = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”,“Status”, 116)
luup.inet.wget(“192.168.1.50//?relayState=”…state…“&”, 1)
os.execute(“curl -k https://api.spark.io/v1/devices/55ff6e065b75555336212345/led -d access_token=2ffac8e46a02fa91b721e974ada7198e0d54321 -d params=l1,”… (state == 1 and ‘HIGH’ or ‘LOW’) ,1)[/code]
do I have a syntax problem?
