Lua startup
First, thanks again Richard! I just love your plugin, can’t imagine my setup without it.
To resume my problem i have a nice setup, arround 30 real zwave device and many virtual. I use pleg to manage all my light. But sometime in the middle of an action my vera just do a startup…no reason. The next time this condition will run it will run without problem. Sometime it’s once per week that it “crash” in the middle of an action. But sometime it’s twice or more per day…and i don’t know where to look since it’s always random, never the same device/action etc…
I have a vera 3,
Thanks guys
Do you use Vera Routing ? I.e. do you have a nightly heal ?
Hi Richard, sorry for late reply was sick.
Yes vera heal each night. I found that many time it happen is when a schedule run. IE at night or at day.
Here is my schedule for night or day
sIsDay Weekly +00:15:00r 1,2,3,4,5,6,7 None Interval 10 None false 2014-12-18 07:44:51.100 2014-12-18 07:45:01.100
sIsNight Weekly -00:10:00t 1,2,3,4,5,6,7 None Interval 10 None false 2014-12-18 16:03:26.004 2014-12-18 16:05:03.104
The schedule run correctly, it launch the condition action but fail in that action and do a startup. Only partial action are run.
What are your actions …
condition:
SwitchDay Yes sIsDay false 2014-12-19 07:45:28.110 2014-12-19 07:45:38.102
SwitchNight Yes sIsNight false 2014-12-18 16:03:26.015 2014-12-18 16:05:03.107
Actions for Condition: SwitchDay
Device Actions:
Immediate
Device Action Arguments
Status SetStatus7 newStatus7=1 //virutal switch
Actions for Condition: SwitchNight
Device Actions:
Immediate
Status SetStatus8 newStatus8=1 //virtual switch
Status SetStatus4 newStatus4=1 //virtual witch
Fenetre SetLoadLevelTarget newLoadlevelTarget=100 //light
Led SetTarget newTargetValue=1 //light
Dehors sous-sol SetTarget newTargetValue=1 //light
Lumiere cote SetTarget newTargetValue=1 //light
Lumi?re avant SetTarget newTargetValue=1 //light
What happens when you change your Virtual Switches … does this kick off other scenes or PLEG conditions ?
sorry was sick like hell!
So after you wrote your message i checked everything. Yes i was starting event after i trigger a virtual switch. So i remove that part and so fare no problem. So to resume
Pleg had a event → Switch a virtual Switch → When the virtual switch was trigger → Pleg start other event. And that caused the problem. Maybe too much memory don’t know.
