I need a z wave enabled low voltage switch. I basically need a device that on a ‘close/on’ command from Vera closes a contact and on ‘open/off’ command opens it.
Does anybody have a suggestion?
the only one I am aware of is the ZRF-113, runs on 120V, but has an isolated contact closure you could use for low voltage.
http://store.homeseer.com/store/ZRF113---Z-Wave-Relay-Fixture-Module-ACT-HomePro-P386C107.aspx
Specs:
http://www.act-remote.com/HPW/Specs/ZRF113-S100_spec.pdf
Installation, shows wiring diagram as well:
http://www.act-remote.com/HPW/Inst/ZRF113-S100_instr.pdf
I’m using these on low voltage landscape light works great.
