Hi There,
I have forgotten my password of my Vera 2.
I realy don’t want to install all my devices again.
Can i Change it with putty. I logged in with the pass on de back.
Username is known.
gr Hendrik
Hi There,
Username is known.
gr Hendrik
If you know what you’re doing, and are careful in the scripting, you can use this discussion to “reset” it:
http://forum.micasaverde.com/index.php/topic,6465.msg40455.html#msg40455
… or you can call the Support lads, and they’ll reset it for you (if you enable remote support tunnels)
Thanks for your quick respond!
how can i check if i enabled remote support tunnels.
From the Advanced button and the tech support tab.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
