Long delay in action
Hi all,
I’ve just started my story with Vera Lite (UI7, Ver. 1.7.690) and still I’m disappointed. My computer is connected directly to Very by Lan Cable and my Vera is not connected to internet.
To my Vera I’ve connect relay Fibaro FGS222 and TKB TZ35D. At my Vera devices for Fibaro FGS222 there is three devices, device no 1 looks like master, device no 2 is connected to relay no 1 (parrent device is device no1), and last decive no 3 is connected to relay no 2 (parrent device is also device no 1).
I’ve set parameter 14 to 0 - means switch is monostable.
Now, I’ve connect to Fibaro FGS222 physical switches S1 and S2. After pressing switch S1 I can see at Vera Devices page that Device 1 (Master) is ON immediately, but Device no 2 is ON after around 90 seconds. Physically relay no 1 is ON immediately. The same when I press switch S1 Device 1 is OFF immediately, but Device no 2 is OFF after around 45 seconds. Now when I’ve associated this Fibaro relay to my TKB switch situation is exactly the same, very long delay before Vera detect that relay no 1 is ON or OFF position.
Another situation is when I’m switching relay on Vera web page - device list. When press Device no 2 to switch ON my physical relay no 1 is immediately ON and also indication on web page is immediately on, but Device 1 (Master) switch ON after long 70-90 seconds. And the same when remotely (from web page) switching off Relay no 1 OFF - physical relay is OFF immediately the same indication on Vera web page, but Device no 1 (Master) status is updated after very long time.
I’ve tried to do the same with Philio Pan06 - similar results.
Do you experience something like that?
Also scenes triggered by time intervals or date/time are not triggered.
Any advice?
