Logs On USB
Hello
I have attached a USB (1 GB) as said in :
http://wiki.micasaverde.com/index.php/Store_logs_USB
and after that checked “Store logs on USB device” on my vera
the Status is “enabled”
i have connected this USB to the computer to check if it is storing my logs. but the PC asked me to format the USB
How can I view logs stored in the USB using a PC?
Regards
Hello,
Vera formats the USB device to ext3. To read it on Windows I recommend this: http://www.ext2fsd.com/?page_id=2
thank you i really accessed the file inside my USB
but I couldn’t understand anything :frowning:
i just want to read logs about my door, if it was opened and when it did
i found too much codes which i couldn’t understand
thank you
You want to set up notifications then. In your device properties, there is a tab for setting up notifications. It can send sms or email or both.
actually that is my problem, i don’t have a stable internet connection
so i need to store it to a USB (external and Local storage) to view them later on
