hi,
logs on my veralite are full of entries like this
ra_nand_block_checkbad: offs:750000 tag: BAD
according to syslog it’s happens approx. twice every 30 secs
Jan 8 23:51:16 MiOS kern.warn kernel: ra_nand_block_checkbad: offs:750000 tag: BAD
Jan 8 23:51:28 MiOS kern.warn kernel: ra_nand_block_checkbad: offs:750000 tag: BAD
Jan 8 23:51:48 MiOS kern.warn kernel: ra_nand_block_checkbad: offs:750000 tag: BAD
Jan 8 23:52:26 MiOS kern.warn kernel: ra_nand_block_checkbad: offs:750000 tag: BAD
logs are pretty much polluted with it. what’s that and how to fix it?
I just bought device couple of weeks ago: should I return it?
These messages are in my Vera’s “kernel log” and “System log” as well. Lots of them.
Jan 15 20:09:04 MiOS_35109345 kern.warn kernel: ra_nand_block_checkbad: offs:55c000 tag: BAD
“nand” is memory so I hope my Vera isn’t dying…
[quote=“C4Vette, post:3, topic:173877”](old, I know, just to keep info together)
Already submitted a trouble ticket.[/quote]
Did you discover what this was? I have a similar situation, where my logs are full of
ra_nand_block_checkbad: offs:1e6c000 tag: BAD
Sorry but MCV says this is ‘normal’.
Their reply was: “You should not be worried about the nand blocks on your unit, as even if you get another one you would be in the same range of bad blocks.”
