I have a logitech 700e camera that works very well for exterior monitoring. I have been trying to get it to work with Vera. There was a previous post where someone said they had gotten to get it to work here: http://forum.micasaverde.com/index.php/topic,4032.msg111312.html#msg111312
I have not been able to get the same result. I have been able to get the camera image using VLC by using the following address:
rtsp://192.168.1.12:554/HighResolutionVideo
and following the instructions from the previous post I have created a device with the following:
Apps → Develop Apps → Create Device
Enter the Following Info:
Device Type: urn:schemas-upnp-org:device:DigitalSecurityCamera:1
Internal ID: (Blank)
Descrition:
Upnp Device Filename: (Blank)
Upnp Implementation Filename: (Blank)
IP Address: 192.168.1.200:554
MAC: (Blank)
Room: <Select/Associate if you already have the room created>
Parent Device: (Blank)
Select “Create Device”, “Device Created” message should appear with new Device ID
Device should now show up in “Devices → All” (It won’t show correctly at this point, but we will add the rest of the settings to fix this)
Next, find this manually added device… Click Settings (Wrench Icon) & Update at a minimum the following fields:
Settings Tab:
URL: snapshot.cgi
Username: blank
Password: blank
IP Address: (Should already be entered in ‘192.168.1.200:554’ format)
Save
But this does not work nor does switching the setting tab, URL: HighResolutionVideo
Any thoughts?
Thanks Jason
