Does anyone else have a problem when you access the status using Ivera or via the web browsers. The scenes sometimes do not run its course. Example, Timer 1 shuts off at 12PM and I access it either way timer 1 does not shut off. It is a hit and miss but more a hit than a miss. I am not changing anything just want to see what the status is.
If you are setting your scene to turn on at a certain time and then turn off after some elapsed time, the elapsed time is stored in memory. If your Vera reboots during that time or I think if you reconfigure something and Save, then the turn off after the elapsed time is lost due to the restart. If the elapsed time is a long time and you want to make sure it turns off, then you need another scene to turn the device off.
Thanks for the reply! All my scene’s are to just turn on or to turn off. I needed a 12hr timer which vera does not offer. They offer 10hr to 24hr. So I had to make another scene to cover the two extra hours. So I am set up that way and it still does not always shut off when I access it from HTTP or Ivera. Any other ideas or am I not understanding your suggestion? Thanks again!
