Here is a mini Howto on using a GE/JASCO Z-Wave Home Theater Remote 45608 to trigger the Schalge Lock using a scene:
CREATE A SCENE:
I created a Scene called REMOTE UNLOCK and added and EVENT to this Scene
The EVENT device is GE HOME THEATER REMOTE 45608 (whatever you name the remote)
EVENT TYPE is set to: Scene is activated
I named the Event “remote unlock” and set the scene to number 1
EDIT COMMANDS:
Now edit the COMMANDS and set the deadbolt to LOCK (UNLOCK is apparently not triggerable via remote)
The Lock command still allows you to LOCK and UNLOCK, it merely triggers the mechanism to throw the deadbolt.
SAVE THE SCENE
EDIT DEVICE:
GO TO DEVICES, select the GE HOME THEATER REMOTE
Edit the Device and select “Treat scene buttons as events see: method #2”
Save this and then RE-ADD the GE CONTROLLER under ADD Z-WAVE CONTROLLER (Don’t remove it, just RE-ADD and this updates it)
You can now edit the label on Scene 1 and executing Scene 1 on the remote now Locks or Unlocks the Schalge door!
I hope this helps
-Eric
Editor, http://www.MyHomeServer.com
