I have a Kwikset deadbolt on our front door that I’ve had for a few years. I have a scene set to run at 11pm every night that does a few things such as turn off the outside lights and lock the front door if it’s not.
So yesterday morning when I get up, we find the door is unlocked. I have an email notification trigger set for when the door is unlocked from when I was testing something that I never turned off. I got an email at 2:07am stating that it was unlocked.
Are there any logs on Vera that can tell me what triggered the unlock? This happened once before a few weeks ago, but I never got a chance to look into it. Any idea where I should start looking?
You should be able to see what happened in LuaUPnP.log. See: Logs.
Strange events shortly after 02:00 are often associated with the Automatic Heal process that gets triggered if there are problems with your Z-Wave network. Do you have any devices that are not working correctly?
I just installed Vera 3 with a yale door lock and I set it to email some events and it has now said it was unlock once in the night and once while I was at work. Did it really unlock? Anyone know why this is happening? I am a total Vera noob.
Do you have something that will automatically relock the lock ?
If not … it should still be unlocked in the morning or when you get home if it really was unlocked.
Otherwise it’s probably a bad alert when vera restarts.
