Localize Vera Alerts Client
If you would like a localize version of the Android Vera Alerts app and would like to contribute … please let me know.
Currently it is in English. It is partly localized in Dutch.
It you can help … please let me know.
There are about 100 strings to be translated.
If you like, I can help you to translate to portuguese.
See the attached files:
The format is
Upgrade from Old DB
The bolded part is where the translation goes.
These strings are spread through out the UI, most are the settings page.
Others are the context menu (when you long click entries)
Please PM or email the changes … including the language … I would like to credit all of the contributors.
Thanks in advance.
I can help to translate in french.
LG
Richard, I will translate to spanish, I will do it on this next weekend.
Great … Thank you … let me know if you any questions about the process.
Richard, here are in spanish. I couldn’t use special characters used in spanish like ???.. and ?. Let me know if you need anything else.
The localization should be able to handle all of the special characters.
Richard, I sent it to your email with all the special characters.
Sent Portuguese localization to your email.
Hi, did you received the Brazilan_Portuguese String that I sent to you by email?
Yes,
That is in the Version I expected to release a few weeks ago …
I made a release last night just to fix the Version timeout problem.
I will make a release with your localization and other changes soon.
