Can I login using Vera’s local IP? It gets the IP from my router which provides DHCP to my network.
Yes.
and you will probably prefer to work with DCHP reservation on your router and fix vera’s IP.
Apart from the IP, what else do I need to login?
Seems when I try to login via the IP assigned by the router (yes I will fix the IP), a dialogue box pops up wanting a user name and password.
Its as though there is a .htaccess file
What credentials do I supply - tried my MCV username and password to no avail.
[quote=“hamishb, post:4, topic:179320”]Apart from the IP, what else do I need to login?
Thanks[/quote]
With UI6 if you are trying to login you will need the account see
http://forum.micasaverde.com/index.php/topic,22736.msg153190.html#msg153190
