The Leviton 2 button scene controller (VRCS2-MRZ) is neat little device. It has two buttons and two load relays which can be quite handy for controlling multiple circuits in tight places. Unfortunately, if you’ve ever installed one, you’ve probably been frustrated by the performance.
Out of the box, the controller behaves as a local load switch. Pressing each button toggles the associated load immediately without fuss just like a pair of ordinary switches. That all changes the moment you include the controller into your network and configure it.
When Vera configures the switch, it breaks the local load association and the buttons stop working. Although you can set up scenes or manual associations to make the buttons work again, they never feel nearly as responsive as they did out of the box. Worse, the indicator lights often get stuck in the wrong state. Occasionally I’ve even seen the switch crash and become unresponsive such that the only way to recover it is to flip the breaker.
You can read about some of the difficulties others have had in the forums. It’s no fun at all.
http://forum.micasaverde.com/index.php?topic=7390.0
http://forum.micasaverde.com/index.php?topic=13251.0
As it happens, there are two ways to configure the VRCS2-MRZ.
- Configure as a scene controller.
If you want to be able to completely reprogram the buttons and you don’t mind poor performance and unreliability, then you can configure the device as a scene controller as usual. Just follow these steps.
[ul][li]Press and hold both buttons until they both flash red to reset the device.[/li]
[li]Restart Vera in include mode and bring it close to the switch.[/li]
[li]Press and hold both buttons until they both flash amber.[/li]
[li]Wait for Vera to include the scene controller.[/li]
[li]Press and hold one button until it flashes amber.[/li]
[li]Wait for Vera to include one load.[/li]
[li]Press and hold the other button until it flashes amber.[/li]
[li]Wait for Vera to include the other load.[/li]
[li]Save changes.[/li]
[li]Plug Vera back in.[/li]
[li]Let Vera configure all three new device nodes.[/li]
[li]At this point, the buttons won’t work at all.[/li]
[li]Create scenes to reassociate the buttons with the loads.[/li][/ul]
Hope for the best. It’ll work but not very well.
- Configure with local load control.
This is tricky but if you get it right, you’ll have the same instantaneous feel you had out of the box. The idea is to preserve the factory association between the buttons and the loads. To do that, we need to convince Vera not to configure the scene controller.
The following steps will accomplish that. They assume you’ve already included the device in Vera and need to exclude it first but you can just skip the first part if that’s not the case.
[ul][li]Disable Vera automatic configuration of devices. (important!)[/li]
[li]Turn off breaker.[/li]
[li]Delete existing scene controller and loads from Vera UI if present.[/li]
[li]Turn on breaker.[/li]
[li]Notice that the buttons don’t work anymore.[/li]
[li]Press the button a few times to confirm that it now locally controls the load and the indicator light toggles green appropriately. If this test fails, start over.[/li]
[li]Manually configure both new load devices. Do NOT configure the scene controller device.[/li]
[li]Delete scene controller device from Vera UI. Deleting the controller may fail silently if the node is reachable which is why we’ve turned off the breaker. We could simply disable automatic configuration for the scene controller device but there isn’t much point to keeping an unconfigured node in Vera forever.[/li]
[li]Verify that the buttons still locally control the loads. If they do, pat yourself on the back. Otherwise something probably caused the factory association to be wiped. Try again. Make certain Vera isn’t trying to automatically configure the scene controller device.[/li]
[li]Re-enable Vera automatic configuration of devices. (if desired)[/li][/ul]
(Note that for my own switches, I included the bottom button first then the top button but I don’t think it matters.)
The end result is that the buttons will locally control the loads. They will behave just like two ordinary switches. Note that you can still use events to trigger scenes when the switches are toggled.
Hope that helps,
Jeff.
