loader.lua does not like forward slashes
Apparently openluup does not like forward slashes inside variables.
loader.lua complains about being unable to concat when a “/” is part of a string inside a variable. (Line 283) while loading a plugin
local source_code = table.concat (loadList, '\n')             -- concatenate the code
I had to insert the value in decimal and convert to character in order to bypass the complaining…
local slash = string.char("47")
local end_request = "<" ..slash.. "IRCCCode><" ..slash.. "u:X_SendIRCC><" ..slash.. "s:Body><"..slash.. "s:Envelope>"
wondering if anyone else has experience something similar?
The forward slash is a special character so you need to use the escape character. I.e. when you want to use / put / in the string and it should work. For some reason Vera LUA does not complain about it, but most other LUA implementations probably will. I know the one on a PI does :slight_smile:
Cheers Rene
Thanks for the head up … Although I did try your suggestion before the Hex conversion but for some reason it did not like escaping the “/” with a "" … it was weird though…
