Linking two switches -Help
Hi all, I am trying to replace two switches in a 3 way config using Elvove LRM-AS and Evlove LSM-15. I have all the wiring done but I am having issue linking them together. I am running a Veralite. Vera sees both the dimmer and the remote. So under the remote I go to “device options” and add group 1 then under setto I put the check mark on the dimmer i want to control. Save and everything looks good, but switch does not do anything when pressed. If anyone knows what I am doing wrong please help. Thank you.
You’re trying to associate a dimmer with a switch. Contrary to the documentation, this association no longer works.
You need a LTM-5(Linear WT00Z-1) to do (virtual)3-way configurations. The LTM-5 is a Z-Wave controller one button controller, it does not directly control a load. The LTM-5 can be associated to either a LRM-AS dimmer or an LSM-15 switch . It can also control other Z-Wave devices like an appliance module.
The LTM-5/WT00Z-1 can be associated with a maximum of 5 devices at the same time.
Thanks for clearing that up, will have to buy a new one.
