[url=http://ecx.images-amazon.com/images/I/717MFRtMnRL._SL1500_.jpg]http://ecx.images-amazon.com/images/I/717MFRtMnRL._SL1500_.jpg[/url]
FYI - I just purchased this LinearLinc BulbZ Z-Wave Dimmable LED (LB60Z-1) on Amazon and although it works in UI5, I get a configuration error with vera failing to get the version number. Although this message stays, the bulb works well in UI5 (but the message is annoying to look at)
I installed it on my vera-edge with UI7 and the bulb also works perfectly (without the “Failed getting Version” error message).
I just bought the same bulb for my UI5 and I ran into the exact same situation (it works but UI5 keeps getting stuck at “failed at getting the version”). Have you been able to find a resolution for this issue?
Yes I upgraded to the latest firmware
[url=http://forum.micasaverde.com/index.php/topic,27870.msg232192.html#msg232192]http://forum.micasaverde.com/index.php/topic,27870.msg232192.html#msg232192[/url]
