Linear WD500Z Minimum Load
Does anyone know if the Linear WD500Z requires a minimum load like the Leviton VRI06? Read the Linear literature and can not find any mention of a minimum load.
There is no minimum load requirement. I have tested the WD500Z-1 with as little as 6 watts and it has worked fine.
Thanks.
