Line Voltage Thermostats Replaced
I successfully replaced my POTS Thermostats from three of my rooms. I bought a product that I saw mentioned in an earlier post at this forum.
http://www.aubetech.com/products/produitsDetails.php?noLangue=2&noProduit=42
The install went well. It took me an hour for each unit. Instead of installing them at the register, I installed them next to my breaker panel. For purposes of the low voltage wiring it simplified the install instead of wiring to each baseboard. I also bought a Radio Thermostat and a Walwort power supply. I would suggest this product to anyone & the price was great…
Tazzman
This is interesting. I have long been pondering use of these Aube relays.
I am curious, as you installed the relay at the panel, where did you place the thermostat? Did you run low voltage wire to multiple locations near each baseboard heater?
Alternatively, do you have the relays installed in series such that multiple baseboards in multiple locations are being operated by a single thermostat?
I have a central location at my Cottage. You can see in the photo that my low voltage wiring goes from relay to relay.
