Lights coming on when I SAVE
whenever I make changes to devices or scene and click the red save button on the top right, VeraLite goes to work and after it’s done with the “Unit Busy” phases, several of my interior and exterior lights turn on. Anyone else ever have this problem? It’s alway the same interior lights and one set of exterior floods.
The problem appears to be with scenes that have triggers based. I have a scene activated with a button on a 4-button in wall scene controller and another scene that turns on motor court flood lights when the driveway gate is opened. I have deleted the triggers from those scenes and now the lights do not come on when I save.
Additionally the scenes were activating each night around 2-3am, two times. That’s been a real pain. Maybe the unit does some maintenance at night and somehow the scenes get triggered by that. I hope deleting those triggers has fixed them coming on in the middle of the night. I’ll know more in a few hours.
A nightly heal runs if there are nodes that are not optimal in your zwave network.
After completion then Vera restarts. You can disable this behavior I think by unchecking one if the options which I think might be “use MiOS routing” IIRC
Nothing came on last night. I’ll see if I can review the reports and fix any node that need attention and then turn the triggers back on.
