Lighting plan. Suggestions/Thoughts appreciated
Ok, I’ve attached a png file with my main living space (living room, kitchen, and dining room). I’ve marked out where in the living room I’d like to put my recessed lights. I know it seems like a lot, and I’m not 100% sure this will be what I do. Note that the spacing was done really quick and is likely not accurate in the image, but you kinda get the idea. Let me describe what the colors represent:
[ul][li]Red - General lighting 6" cams. Mainly will be used for “Cleaning” and when the kids play in the living room. I personally will probably never use them otherwise, but it’s nice to have them for cleaning. We currently use the sofa table lamps as general lighting and one torchiere lamp that I’d love to get rid of.[/li]
[li]Yellow - TV/north wall lights - 3-4" cams (what ever I can get that is IC) tv is mounted to the wall, but I do keep a tv stand under it that holds nick knacks and stuff. All the AV equipment is in a closet across the room with a rack opening about where the left most pink light is. this opening will be covered with a hinged panel/art[/li]
[li]Blue - East wall lights - 3-4" cams - This is for highlighting art that is on the wall, or just generally washing the walls with light.[/li]
[li]Pink - South wall lights - 3-4" cams - wall washing or for lighting art [/li]
[li]Brown - West wall lights - 3-4" cams - wall washing or for lighting art (I may actually add another as this is a 12’ wall like the yellows)[/li][/ul]
So, my thinking is this and before I say this, let me say that I haven’t installed lights yet, I’m just in the planning phases, so I can wire it however I like (multiple switch locations, etc). I figure I have a few options:
[ol][li]3 switches - Red are on their own switch, Yellow are on their own switch, the rest share a switch[/li]
[li]2 switches - Red are on their own switch, the rest share a switch[/li]
[li]5 switched- each ‘zone’ is on it’s own switch.[/li][/ol]
Obviously the 3rd option is the most “flexible”, but it will require 5 switches and that doesn’t include the fan control (no light, but I 12/3 going to it in case that ever changes). I’m also thinking of doing 3-way with switches near the entrance on the bottom right (foyer) and on the little wall between the dining room and kitchen on the living room side. I was also considering doing switches for the hallway in the bottom left, but I think that won’t be necessary. I’ll have switches there for the Dining room lights so you can turn them on to get to the living room lights.
So, I’m sure everyone thinks I’m crazy, and I might very well be. Am I putting too much light in this room? It’s our general Living room/Home theater (I have 7.2 surround sound in there and I will be moving up to an ~80" tv). I want the control for “movie nights” and for parties. I thought the bathing of the walls would be a nice effect for high lighting the art we have on the walls. My GF definitely thinks I’m crazy, but she thinks the whole Z-Wave thing is crazy as well, but she’s going along with it all anyways.
Anywho, basically any thought on the best way to do this, or if I’m just crazy would be appreciated. My only other concern is that I would like to go with LEDs, which makes option 3 very hard. I may end up using the halogen bulbs in those just to make sure I make it over the min wattage requirement.
In my opinion, the more control the better. Or, you could at least wire them as individual zones, and tie them into the same switch in the gang box. You could start with a smaller gang box, and later make it larger.
You could also use inline dimmers, and not have to use switches directly. Then you could simply add 1-2 controllers, and have them take care of everything.
You can do this with either Z-Wave or Insteon.
Also, I know you don’t plan to use them for general lighting…but be sure your “red” recessed lights are far enough away from the ceiling fan to avoid the “flashing” that occurs when the blades are in motion. It can be really annoying.
As you said, the more switches the more flexible your lighting options. For me the only limit would be budget, but if you can afford the switches, why not. For that matter, even if I could not afford the switches right now, I would still wire for the switches and use standard switches until I could swap them out with Z-Wave.
I don’t see how using LED form the onset is any more problematic than using halogen or any other type of bulb. Except for cost, again, I would use LEDs.
Too much light? You don;t provide room dimensions or ceiling height so it’s impossible to say. If the drawing is to scale and the cited wall is 12’ then I would guess that the room is amply large for that many cans. The right amount of light is really a taste issue, but even if you are using “too many”, dimmers make it a moot issue.
For my greenfield home, I would use LEDs and Z-Wave dimmers. Enjoy, I’m sure you are excited!
Also, @PurdueGuy is right on about ceiling fan clearance, it can be maddening.
Thanks for the input guys!
I was thinking on home running each zone to the switch locations anyways. I’m thinking that even if I just combine the 3 back zones into 1, I can use false covers in the gang box for now (2 would be switches, the other 3 would be blank fillers for now). I think you’re right though and I will definitely be doing this.
[quote=“PurdueGuy, post:2, topic:176678”]You could also use inline dimmers, and not have to use switches directly. Then you could simply add 1-2 controllers, and have them take care of everything.
You can do this with either Z-Wave or Insteon.[/quote]
I didn’t know they made them, I will research inline dimmers. They might be better, but I almost prefer the wall switches because if I sell the house, I can take my Z-Wave stuff with me and just put in regular switches and outlets.
Yes, I had to do this when I put my fans on my back porch. But thanks for the reminder. Actually the fan in my office right now (with a light kit) does this with it’s own light and now that you mention it, it’s annoying. Thanks alot!! :stuck_out_tongue:
I agree. I’m gonna go ahead and “home run” the zones. My GF just approved this plan, so I just need to get the supplies.
My problem with using LEDs is the flashing problem you get if you don’t use resistors or you don’t meet the 40w minimum (for leviton, which is what I plan on using). If I combine the east, west and south walls, I’m sure I’ll meet the 40w minimum for that zone. The same goes for the 6 general lighting cans (9.5w each). The yellow zone, or any of the wall washing zones if I split them apart, won’t add up to 40w individually. I’m thinking the VRE06 leviton switches might be ok for those, but then I’m looking at $200/zone just for the dimmer. That is a bit pricey. I did read today on adding the resistors in the cams, but I’m not sure I’ll have the space in the 3" or 4" cams (depending on which size I go with).
That is my only concern. I actually prefer LEDs and use them in most if not all my fixtures (i may have a CFL here or there still).
Yes, sorry, the room is roughly 12’x20’ with 8’ walls. I plan on actually making sure 6 will work for the general lighting. My back porch is 13x17 and I used 6 out there (and it has great coverage, and is BRIGHT when all 6 are on, like showroom bright!).
You’re right about the dimmers. I already have 4 speakers in the ceiling and I guess my concern was that if you ever looked up at the ceiling it would just look like a complete mess…LOL. I’m thinking of painting the light trims though to the ceiling color so they blend in. The speaker grills are painted and they disappear pretty well.
[quote=“Z-Waver, post:3, topic:176678”]For my greenfield home, I would use LEDs and Z-Wave dimmers. Enjoy, I’m sure you are excited!
Also, @PurdueGuy is right on about ceiling fan clearance, it can be maddening.[/quote]
Thanks, and I am excited, but to be fair, I do stuff like this all the time. It drives my GF crazy! At one point I had all the drywall off a central closet in the house so I could move studs around for a rack opening into the living room and for my SMCs in that closet. I really do love this stuff :slight_smile: I’ve attached a few pics of it. and if you (or anyone else) is really interested in it, you can read my build thread over at avsforum.com on it: http://www.avsforum.com/t/1470115/my-home-theater-rack-and-equipment-roo
A valid point! Good luck explaining Z-Wave and hidden dimmers that you have to exclude/include to newbies!
Which brand of switches are you considering?
Right now, due to past experiences with non z-wave stuff, I’m going with Leviton. My only bad experience so far is that I have, and it’s not that bad realy, is that I have 2 lamp dimmers. The GE dims quite a bit better than the leviton. It just seems to take the light down further (LED bulbs) and the levition seems to be brighter at say 5% than the GE one does. Besides that, I’ve use Leviton non z-wave dimmers in the past and I like them. I have one installed right now for my back porch lights.
BTW, another idea I had was to use all Philips Hue bulbs for the color effects and such, but I’m not sure if they’ll work in 4" cams (as I would prefer to not put 6" cams along the walls).
Then I could just put in a 5-6 gang box, put one switch in for the fan and either use scene controllers in the others or just use fillers. Would be kinda cool though to be able to bath the walls in colors for mood lighting :slight_smile:
I likes the Philips Hue bulbs, but ultimately had to return them. They simply weren’t bright enough for me, when I wanted them to be bright.
The output is max 600 lumens, and decreased based on color selected, etc.
So I’ve been pondering on this since August when I first posted this. My idea now is to put a big junction box in the attic (meets local code as long as the opening points up ^ and is accessible). I will then put a 1-3 gang j-box on the wall in the locations I want control. I will wire the Aeotec dimmers in the attic junction box and put scene controllers in the walls for controlling “scenes”. I’m going to buy a test dimmer and some lights with the LEDs I intend on using and setting up a test station to see how they react.
I’ve used Leviton dimmers all through out the house and my only issue right now is in my new Master Bath, I have 2 4" LED trims that just don’t dim well on a leviton switch. they dim up…stop for a period of time then continue dimming up (however, they dim very very low!!! lower than any of my other lights). Basically there is a point in the dimming range that it just stays the same brightness. The 3 bigger 6" trims from the same company (ecosmart from HomeDepot) that dim wonderfully on the same model of switch. My guess is that it’s just not enough power in the two lights for them to dim smoothly. I have some other lights that have the same issue, but too a much smaller degree. The test station will be so that I can test all the components before actually installing it and making sure I’m not wasting money.
I want to thank everyone for their ideas. If of course anyone thinks I’m just crazy, please let me know now…LOL.
Philips came out with a BR30 downlight. That might help with that dim light I was getting.
At least the new bulbs are 600 lumens but mostly focused down, where the other were 600 lumens in all directions.
[quote=“SirMeili, post:9, topic:176678”]So I’ve been pondering on this since August when I first posted this. My idea now is to put a big junction box in the attic (meets local code as long as the opening points up ^ and is accessible). I will then put a 1-3 gang j-box on the wall in the locations I want control. I will wire the Aeotec dimmers in the attic junction box and put scene controllers in the walls for controlling “scenes”. I’m going to buy a test dimmer and some lights with the LEDs I intend on using and setting up a test station to see how they react.
I want to thank everyone for their ideas. If of course anyone thinks I’m just crazy, please let me know now…LOL.[/quote]
Please be aware that not all Leviton dimmers are created equal… meaning, they have specific models for dimming LEDs and electronic loads. Which ones are you using?
I have used both VRE06-1LZ and VRI06-1LZ. The former requires the Neutral, the latter doesn’t. The first 2 I installed was one of each, in nearly identical setups. I have a back screened in porch and a kitchen, each has 6 recessed lights with EcoSmart 6" LED trims. They both operate identically. I realize that both of these meet the 40w minimum requirement even though they are LEDs (or were ridiculously close to 40w). The bathroom has 4 sets of lights (Shower, Bath, General, and Vanity). The Bath (2 Cree Bulbs from HD) and the General lighting (3 6" EcoSmart trims) both work ok. The bath doesn’t dim all the way down before cutting off, but I think this has more to do with the bulbs than the dimmer). The shower (2 4" EcoSmart trims) do not dim very well. The bathroom all uses the VRI06-1LZs (no Neutral). Since I know the kitchen will work without the Neutral, I may take it out and put a VRI06-1LZ in and try out the VRE06-1LZ in the master bath.
For the living room, I will be testing the Aeotec’s micro dimmers first, but I have some spare levitons I can use for testing as well to see how they work out in case the Aeotecs don’t work out. Even if I go to leviton, I will be testing them as there is a $100 premium for the VRE06-1LZ that I would prefer not to buy if I don’t have to. If there is another Leviton dimmer I am missing, please let me know. I did my research and for some reason I chose those 2 for testing initially based on that research.
It is my thinking that the 6" Ecotecs are made to accept normal incandescent dimmers as they actually dim very smoothly and the ramp up is very smooth and even. My guess is that the 4" do not do this or they are no providing enough power to do it.
@SirMeili - I was, once again, admiring your fantastic project. I’m really curious about three things.
  1. Noise. I didn’t see that you did any insulation. Is the equipment in your “closet” audible?
  2. Heat. How hot is it and how are you managing it? You mention possibly installing a thermostatically controlled fan. Did you implement the fan and is it audible?
  3. Power. With the always on equipment and the added thermal load, what sort of impact has this closet had on your power bill?
Any regrets?
@SirMeli
I think you’re on the right track in your observations. The VRI06-1LZ can not be used to reliably dim anything other than an incandescent load (hence the “I” in its model name). The VRE06-1LX is the correct dimmer to use on low-voltage electronic transformers and LED loads. If you’re willing to change switch design style, the Evolve dimmers will also work to dim LED loads, but they are only about $50 each.
Hope this helps,
-TC
[quote=“Z-Waver, post:13, topic:176678”]@SirMeili - I was, once again, admiring your fantastic project. I’m really curious about three things.
  1. Noise. I didn’t see that you did any insulation. Is the equipment in your “closet” audible?[/quote]
I did not do any insulation and here’s why:
[ol][li]There is a gaping hole in the wall for the rack. Any insulation I would have done likely would have not helped with the sound since there was still a major place for the sound to come through. I do plan on putting a “door” over the rack opening, and I will likely insulate that somehow or use it for Game/Dvd storage.[/li]
[li]I did lots of research into sound proofing and besides the above reason, there was just too much to do to do it propertly (offset studs ,2 layers of drywall with the green glue between them, etc).[/li]
[li]I don’t really notice it. For the most part the TV is on, and the couch is about 10’ from the wall with the rack, so you don’t hear it (I have 7.1 surround sound). Even then, the only time you can really hear anything is when everything is off and you can hear my Development server/File server. It has 7 fans in it and they are on pretty much full blast 24/7. It’s also about to get a lot worse as i have 7 of the Vantec Tornado fans to go in there. My hope is to make an external fan controller so that they will only run as much as they need to (each one sounds like a hair dryer…LOL). I had found one that would have fit my needs perfectly, but they no longer make it/sell it[/li]
[li] I decided that this might actually help hold heat in the room, which isn’t something I wanted.[/li][/ol]
Please note that all my other equipment either does not make sound (no fans), or in the case of my HTPC has been optimized to only keep the fans only high enough to keep the system cool. For the HTPC it means you hear the initial spin up (it’s how we know it actually turned on) and then within a second it is silent.
I live in Florida and hasn’t been that much of an issue. My saving grace is the Central Air’s Air Handler that resides in that room (and it is audible when it kicks on and runs). When they installed it in 2011, I didn’t have them put an air intake through the wall. There is a vent in the door and the Air Handler sucks in air through the close door and therefore through the closet. This works well in the summer to keep the room fairly cool (about 80-85, with the Ac set at 75-80) in the summer. The winter, oddly enough is a different story. That room can easily get 85 while the rest of the house is quite cold. This is because we don’t always run the heat. So I had to do somethign about that. I bought the HiFlo vent system from Coolcomponents and actually installed it this week (we were running the A/C as recent as a couple of weeks ago! Crazy Winter!!). It has a thermostat hooked up to it that regulates the speed based on temp. So far this fan has helped a good amount (it is placed up high on the wall). THe fan points into the hallway and if you are home alone and it is on full blast and you listen carefully, you can year it. I might opt to swap out the fans at some point to some higher CFM ones to see if they work better with only a little bit of some noise.
Another interesting thing I found was that during me doing the final painting of the trim for the around the rack (living room facing side), there was a ton of dust around the opening. I also had some light bleed when someone turned on the closet light. What I did to help with this was to put some rubber weather stripping on the back of the trim so that when the rack is pushed into place, it creates a seal (well, that is what I hope it does). It does help significantly with the light bleed, so there is that.
I was running most of the equipment anyways before I did the closet. It was just spread around the house. The HT equipment was in my TV stand that sits under the TV (TV is wall mounted, the stand jsut keeps the kids away from the TV). The Server was in my old office (now my new master bedroom) and that room was ALWAYS 5 degrees hotter than the house. I thought it was the room, but it turns out it was the server. It is now the coolest room in the house (by 2-3 degrees). Some of that may be removing the giant bay window and putting a sizable bathroom attached to it (I actually think this helped cool it down, but even after removing the server before construction, it was noticeably cooler).
The only additional equipment I’m running is the Home Theater’s batter backup and power regulator. It replaced a belkin version that died a few years ago, but belkin stopped supporting it. They actually bought it back from me for more than I paid, so I wasn’t complaining… It was an awesome piece of equipment though and had more features than the expensive APC one I have now. the only thing wrong was the battery pack was bad. Anyways, I’m off topic.
It’s hard to tell if the room has any affect on power because shortly after finishing it, my Fiance and her 2 kids moved in and the power bill definitely went up. Right now in winter I would normally have a $100 power bill, but it is now $200. Some of this is the fact that my Fiance is taking 6 months maternity leave, so we are both home 100% of the time (I work from home). Anyways, except for the minor additions to help keep the room cool, I don’t think there is that much of an increase in power usage. Like I said, it was all being used before, just in different places. That being said, the closet is still a continual work in process and most likely more equipment will go in as I get the AV Distribution and Whole House Audio put in over the next few years. I’m actually thinking of putting in another of the cool components HiFlow Vent systems in at some point to see if I can get the temps down more.
I’ll attach some pictures of the HiFlo vent system installed. I paid extra for the oak grills because they looked more finished and I just put in all new trim. i didn’t want a cheap looking plastic trim in the main part of the house. If I buy a second one I will get the plastic ones and use the wood ones on the outside and the plastic ones on the inside. Note that I did put a recessed outlet right next to it on the inside (or I will be, the power isn’t run yet, that will be done this weekend). I did this because I can run the 12V cable in the wall a few inches to one side of the 3 gang box and then just plug it in. The Vent System doesn’t have a nice way of getting the power cable from the inside to the outside. I’ll likely take pictures and post them to the AVS thread (as will some of my new additions will)
No regrets, but there are things I likely would have done differently.
[ol][li]I would have use a Middle Atlantic Slim rack instead othe Tripp Lite version I did - It’s just heavy and bulky and ultimately hiding the rack from the living room took some trim work and some creativeness to hide the rails. IT looks amazing now, but as you probably read in the AVS thread, you could still see the U marks even with the MA trim strips on.[/li]
[li]The UPS for the 2 SMCs and the modem is a bit high and the recessed outlet box behind it is a bit high (and hard to plug stuff into). The UPS fits, so it’s not a big deal, but it’s close to the ceiling and I’m scared the UPS isn’t venting properly. The new Vent fan is right next to it, so i’m sure that will help.[/li]
[li]I put the APC Home Theater UPS on the bottom of the rack. One day the 4 y/o hit the pretty blue button…RACK DOWN!!! (except my server which has it’s own UPS). Not a huge deal, but I now see why everyone puts those on top. I could just rearrange the rack, but I custom cut and ordered specific size cables to keep it tidy back there. Right Now I’m thinking of making a custom Plexiglass face plate to cover it. The face plate of the ups comes off to replace the batteries, so I will likely use Plexi and some straps to hold it on then strap it around the UPS’s faceplate. The challenge will be making it look nice.[/li]
[li] As you read from the thread, I put in 3 8-gang low voltage mud rings under one of the SMCs. Not only were they expensive, but so were the 8 gang faceplates. My idea was to make the rack 100% removable. Had I really thought it through, the rack is 7’ tall and won’t go through a door. I also used a ton of quick port faceplates and I think that brush style ones with just the cables passed through would have sufficed.[/li]
[li] I wish I had some kind of sound proofing, but not for the equipment. For the Central Air! I’m used to it, but since it butts up against the living room wall you can hear it kick on and hear it running. It used to be in the attic, but in 2011 when the replaced it, they said they will no longer put them in attics. Luckily I had a 4’x6’ closet in the middle of the house. That is the reason it is now an equipment room. At one point I was going to tear down two of it’s walls and make it an open den for the bedrooms (2 of the walls would block it off from the foyer and living room). Anywho, the A/C can be loud and I’m not a huge fan of that. Of course, that being said, I didn’t remove drywall in the whole room. I left it behind the A/C because it would have been near impossible to redrywall it. That and as i said before, I read that normal insulation doesn’t offer that much sound proofing and it wasn’t withing my budget to do offset studs and multiple layers of drywall.[/li][/ol]
Note that certain decisions of mine were made because i had some very specific needs. Had I not had the Development server that I wanted hidden from the outside, I might have opted to use one of those pull out racks that slides out. It likely would have made the tilers happier.
Thanks for the interest. If you have any other questions, please feel free to ask them here or on AVS :slight_smile:
[quote=“TC1, post:14, topic:176678”]@SirMeli
Hope this helps,
-TC[/quote]
I like the Leviton name and the style of their switches. I will use the VRIs where I ahve to, but I’ve noticed that the VREs will dim LEDs quite well depending on how the LED bulbs were made (some are made to work with that style of dimmer from what I understand). Due to the $100 premium, I will not buy a VRE unless i have to.
@SirMeili - Thanks for the update! Very informative.
