Lighting behind mirrors.....just wait...hopefully it'll make sense!
Ok, so we are in the finishing stages of our year long Master bath addition (most of the delay was due to our new son Orie and just life in general as well as other projects in the house). When we designed out bathroom, we were going to have vanity lights over each sink. Well, when we “designed” the bathroom, we hadn’t yet picked out a vanity or mirrors, so we had no idea that the placement of the boxes for the lights were going to be oh so bad. There was actually no way to mount the mirrors and the lights (top of the mirrors stick out further than any lights, so even moving the boxes up wouldn’t work). We also had 3 6" recessed general lighting cams, 2 4" recessed lights in the shower, and 1 above the claw foot up that will eventually be a small chandelier (currently an enclosed ceiling fixture due to “code”). Because of all the excess lighting, we decided we didn’t “need” the vanity lights, so instead of relocating them, I covered them and they are currently behind the mirrors and I remove the z-wave switch I bought for them.
Then today, I had an idea. The mirrors actually sit off the wall about 1/4" (due to the 4 mounting brackets). I was thinking that maybe it would be cool to put some LED strips behind there and hook them up to the power. I’m thinking this could give a nice “glow” around the mirrors and would just be a “neat” factor and not really functional. Here are the issues/options I’ve considered so far:
[ol][li]This is a CBS construction room and the mirrors are on an exterior wall. Because of this, the boxes are rather shallow (they didn’t use deep boxes and chip out the concrete like I normally see). Because they are behind the mirrors though, I am ok with removing them, chipping away the block and putting in deeper boxes (much like was used in the rest of my house). This will allow me to put in “recessed” outlets to plug the lights into.[/li]
[li]I could just uncover (or put a brush cover) over the outlet and put some Aeotec microswitches in the boxes (there should be room for this) and hard wire the LEDs somehow. Not sure this is really at all possible or if I’m just being hopeful. I guess even with this method I need to somehow plug in the lights. So I guess this option is out![/li]
[li]I’ve thought about using RGBW leds so that we could set some mood lighting. I’m thinking of an arduino solution, but I once again run into space issues. For this one, I might actually put another whole in the wall for another outletbox (2 gang maybe?) and store the arduino in there. The mirror will cover it, so no need to cover the actual box. I might have to actually do 1 as well as this one so I have a way to power the arduino. I might be able to fit a recessed outlet in the current box, but I’m not sure.[/li][/ol]
Am I just crazy? Will this not really be worth the effort? Like I said, if the drywall gets a bit messed up behind the mirrors I’m ok with that. I will likely patch it back up and repaint after doing any modifications anyways, but its not like I’d “have” to.
What about the Arduino solution? I could even wait to see if Fibaro releases their RGBW controller to the US and use that I supposed. Right now even just white I think would be cool and if I could find “dimmable” led strips that can be dimmed from a z-wave switch, all the better. I have a 5 gang switch plate that currently holds all the switches and 1 is just a blank due to these lights.
Any thoughts or suggestions are appreciated. I’m even open to alternate ideas to this. I’ve attached a picture of the bathroom without the mirrors and one with. Sorry for the bad panoramic picture of the one without the mirrors… I just didn’t have luck and I couldn’t find a better one.
Edit: I should also note that those are 4" boxes for the vanity lights. The dumb ass electrician used 4" boxes with a cover that has room for 1 outlet. From what I can tell he should have used the one with the round hold (as when I had the lights up, it was a pain in the ass to hook them up). So I can also replace the single gang opening with a 2 gang or circular one. I never called the GC on it because by time I realized it, I was just over it and the lights did fit, they were just a pain to put in.
very cool.
I’d just put some nice wood block spacers on the back of the mirrors so that:
a: they stand off the wall a bit, allowing more light to leak out of the sides
b: allow for you to for the transformer for the LED’s
2cm off the wall ought todo it. keep them inboard of the perimeter of the mirror frame by at least 10cm. start there, easy to mock up and you can make this very nice.
there are colour changing strips now, so maybe you can even make them report the weather in the morning!
go big or don’t bother
[quote=“Bulldoglowell, post:2, topic:179993”]very cool.
go big or don’t bother[/quote]
Due to the “brackets” that they hand on (one in each corner), the mirrors already sit off the wall a bit. This is what gave me the idea. Unless you are suggesting I actually bring them further off the wall. I’m gonna go measure the distance from the wall right now… one sec… ok, so they actually sit about 5/16ths - 3/8ths off the wall. I might need some extra blocking, but I don’t want to go too much further out, but I could probably block them out a bit more.
As to the weather idea, that is just awesome! My fiance just rolled her eyes, but I know she’d love it. She’s always asking “What’s the weather supposed to be like today!?!?”
Keep them ideas coming people :slight_smile: I’m gonna start shopping for parts!
Instead of fighting the shallow box issue, why not pull the electrical up into the ceiling. You can put a junction box with receptacles or microswitches up there and have plenty of room, should you need it, for transformers or whatever.
@Z-Waver. That would require a lot of removed drywall since its an exterior CBS wall with foam insulation. Also the attic is almost impossible to access above that room.
Good idea but it would almost mean redoing the upper part of that wall and the ceiling. As a matter of fact that room is about 80% CBS walls. The other 20% is where the garage door opening was.
Sent from my Nexus 7 using Tapatalk
I should also note that the room waa wired for EVERYTHING! I have so much cat6, rg6 and speaker cable it’s insane. Due to how I had run it though it will be near impossible to re run any of those wires. Here’s a picture before the drywall went up.
What about this 6’ stick-on RGB lightstrip from Philips Hue:
It uses the same base station as other Hue lightbulbs. Needs a small AC power brick.
Not bright enough for a a primary bathroom light, but good for adding some accent lighting.
Ouch. I see the problem now. I had assumed that the wiring in the boxes went up into the ceiling, but I see in your pictures that they daisychain inside the wall.
The Hue might fit, as @AgileHumor suggested. It would also allow you to use RGBW.
I think that the only other way to hide what you want is to us a Z-Wave microswitch and a low profile power supply like this Ledwholesalers 30 Watt LED Power Suppply Driver Transformer. Even with this, it may be necessary to recess it into the drywall/foam a little bit.
I think that the only other way to hide what you want is to us a Z-Wave microswitch and a low profile power supply like this Ledwholesalers 30 Watt LED Power Suppply Driver Transformer. Even with this, it may be necessary to recess it into the drywall/foam a little bit.[/quote]
Thanks for the link! I wish it had one of those right angle plugs on it though. I’m gonna take one of the mirrors down today or tomorrow and see how much room is actually in the box. I’m hoping it’s a standard depth instead of a shallow (I’m hoping I’m remembering wrong).
I am considering the Hue strip, but at that price, I’m gonna hold off a bit. I might see what comes of the arduino RGBW project as well. My only other concern is that I would want to create a rectangle out of whatever I use and that might not really going to be possible with the hue. I see you can cut it every 4 inches, but I would need to know if I could use wires to solder them back again at a 90 degree angle.
I’d cut the plug off the power supply and wire it to a microswitch in box 1(assuming you don;t use a Z-Wave wall switch for that circuit). Then run low voltage on the existing cable from box1 to box2(Label both ends FFS), where the second LED strip is directly connected.
A shallow box would be no problem in that scenario.
Line===Microswitch===Powersupply=====LED1
====================LED2
Looks like their cheaper at the apple store by $30.
You would need 2 qty of Hue lightstrips ($89) + the Hue base unit ($199 w/3 bulbs).
Most 3rd party remote apps support Hue RGB too so you can change the colors on your phone/tablet.
Definitely understand the price issues, I only got one light strip at the moment behind the Living Room TV LCD and it works well. At only $89, it was easier to convince myself :wink:
@SirMeili, distressed wood-look tile from Home Depot? Looks like the exact same tile we just installed in our beach-house style bathroom.
I would go with either an SMD 5050 Warm White LED strip or an RGB LED strip and gin up an Arduino gateway and Arduino node to control it http://forum.micasaverde.com/index.php/topic,16170.0.html. I knew nothing about Arduino before jumping in but Hek has made it super simple - there are two threads on PWM Dimmers - one for Single-color and one for RGB+W. I am working on a generalized multi-channel circuit and sketch that I will share all the details on and you can easily leverage for this project - oh, and you will have fun doing it :slight_smile:
Warm White LED - http://forum.micasaverde.com/index.php/topic,23342.0.html
RGB+W LED - http://forum.micasaverde.com/index.php/topic,18103.0.html
Generalize multi-channel LED http://forum.micasaverde.com/index.php/topic,23342.msg161427.html#msg161427
The whole project should cost you less than $50 and you will achieve great results - with this approach, if you don’t like them, you have all the flexibility to change it too :slight_smile:
Cheers,
Bruce
We actually got the tile from the tilers who installed it. I didn’t see an exact match at HomeDepot (we checked), but basically yes, it is a distressed wood look. She likes it and I don’t mind it. And actually, we (she) liked it so much, we didn’t stop at the floors :wink:
plus now we understand about the future light over the tub!
very nice, I bet your SO never leaves that room
[quote=“Bulldoglowell, post:15, topic:179993”]plus now we understand about the future light over the tub!
very nice, I bet your SO never leaves that room[/quote]
She does love it, but 15y/o, 5y/o and 6month old means that neither of us gets much time alone. I work from home and she is on “maternity leave” (she actually just left her job to get her teaching certificate and become a teacher). So even when we are lucky enough to have a grandparent watch the baby, I am working and she is usually studying…LOL.
She does sneak away and soak in the tub when she gets the chance!
hey, did you ever get together the stuff you needed for this? I was curious to see where you’d be taking this.
Not yet, I have a series of projects (this, the back landscape lights, my new office desk, etc) that I’m working on. Work has been crazy so I haven’t had a lot of time between work and family.
I am still thinking of the best way to handle it and I’m taking all the suggestions into consideration. I especially can’t wait to do the “weather forecasting” suggestion you made. I think that’s just gonna be the best part of it all :slight_smile:
well I’m standing by waiting for you to teach us how you did it!
