I have a vera plus.
I have dimmer light switch. I want to turn it off 10 minutes after it has been turned on.
This, at first glance, is very easy to set up using a regular scene. However, I am finding that the ‘when a light is turned on’ trigger does not work on a dimmer unless dimmer is turned on to 100%.
I assume the same behavior will exist using pleg ‘light turned on’ trigger? I’d test it myself, but I am not sure how to implement the above.
Does anyone know if there is a way around this, so that it will trigger regardless of the brightness level? Any help on what conditions/actions are needed, would be appreciated.
Thanks.
