Light switches labeled Closed/Opened instead of Off/On
When viewing my devices in Chrome browser, all the light switches are incorrectly labeled Closed/Open instead of Off/On. This is confusing. What is the cause, and how do I fix this? When I view these same switches in the Vera Android app, the switches are properly labeled as Off/On.
fixed in latest fW
HansE, what makes you think the problem is fixed? I updated firmware yesterday, April 23, and the problem remains.
The cause is the garage door opener you installed. There has been other posts on this. But I think they fixed the garage door by changing the file for the opener from a light bulb on off icon that it had when it first came out to a door open close icon. Problem is it affect every switch that used that same file. Now it changed everything to fix that garage door icon/text.
The real fix is to open and close your lights. You really shouldn’t be turning them on and off anyway. That’s what I’ve started doing now that I stopped turning off the garage doors. Come to think of it, it was a bit creepy that they got turned whenever I’d click the button. :-\
Can’t bullsh*t us, we know when you clicked… it got turned off? ;D
In other news if you now push hard enough it OPENS!
In other news if you now push hard enough it OPENS![/quote]
Yeah the mojo is what it used to be… busted!
