Light Switch w/smart energy?
Is there such thing as a 2-way and/or 3-way zwave light switch with electricity usage monitoring or if I wanted per-light-switch energy reporting would i need to stick with the Aeotec micro energy switch 2nd edition?
I don’t know of any switches on the U.S. market that do energy reporting. The Aeon in-wall switches and the Fibaro switches do energy reporting, but that’s about it.
You can of course enter a wattage amount for any switch in Vera. Unfortunately, this will not be an accurate gauge for dimmers.
Thanks!
Do you know if there is a scene controller that also acts as a 2-way and/or 3-way light switch? My search has been futile so far… It seems not
[quote=“gwichman, post:3, topic:188176”]Do you know if there is a scene controller that also acts as a 2-way and/or 3-way light switch?[/quote]There are several, but which one to use depends on exactly what you mean/want to do. For example:
This is a one gang two button scene controller that also switches two loads.
Leviton VRCS2-MRZ Vizia RF + 2-Button Scene Controller with Switches for Multi-Location Scene Control. It is a switch, and a scene controller that can be used in virtual n-way configurations if desired.
This is a one gang one button scene controller. It does not directly switch a load. It can be used in a 3-way configuration with one of the buttons/loads of the above two button controller.
Leviton VRCS1-1LZ Vizia RF + 1-Button Scene Controller/Virtual Switch Remote for Multi-Location Control
