[quote=“rinconmike, post:1, topic:186563”]I had this in the General Forum, but deleted it there to post it here.
I have my garage door set up to open and close and it works fine (door sensor, Evolve LMF, and Garage Door App). One added item I have is a light module set to turn on when the door is open and then turn off when the door is closed. This way we can see it is open if the light is on.
When I open and close the door, it works. However, if I go to open the door again withing 60 seconds, the light does not come on. It seems that if I wait a 60 seconds to open the door, the light comes on. I assume this has something to do with the door sensor setting, but I am not sure what setting it is.
Also, I have the light set to come on with a scene. Is there a better way to do this so if the sensor is in the open setting, the light comes on and is off if the sensor is closed?
Any ideas?[/quote]
I’m a bit confused here a bit, so guide me if I go down the wrong path.
I guess you using Richards Garage Door Plugin for Vera right. It should display a lock and unlock when the door is opened or closed.
I’m assuming you mean that the above is working fine.
Then you have a scene that says (confused here) if the garage door plugin is open? or if the door sensor? (not sure which way you have it) then turn on the garage lights.
I would go straight off the door sensor here and a scene should be fine (I personally only use PLEG now, but that would totally be overkill for only this).
The only problem I might see has to do with Polling maybe? When you open the garage does sensor display correctly in the web UI? Do you see any delay or anything? VERA scene should get its info straight from what you see. If you see the sensor not opening and closing correctly or in a timely manner then you can focus on the sensor and why. I would base your scene (if your not already doing this) on the door sensor not on the lock and unlock icons of the plugin.
