Leviton vrcz4 adding to vera2
If anyone could help me with including this I would be greatful. At the moment the controller is being displayed as two seperate devices. node10 and node11. both are showing red cog. I did read the page which performs inclusion with dongle but I have vera2 no dongle. Thank you in advance for any and all help.
Do a search for “Leviton Controller” either here or on the Wiki. There are detailed instructions and conversations on how to utilize it.
It does appear that you have included the controller properly to Vera, since it is showing up. The two devices is because there are actually two devices: First being the controller itself, and the second being the one light that the controller is controlling directly (through its wiring).
Are you using UI4?
If you see the red cog next to the devices, you may not be fully supported for the Leviton VRCZ4 with your current FW.
JOD.
Is it just me or is searching the wiki pointless? I have NEVER gotten usable results when I do a search on it.
I dont know how to include my 2 VRCS4’s or my VRCS1, I had them included a long time ago in UI2… but I haven’t found info on how to include them or how to configure them for UI4. And, it hasnt beena top priority in my life to mess around with them for hours or risk having to re-include my entire network if I mess something up.
There really need to be an updated wiki on these controllers.
If I had a red cog on these, I’d exclude them, do a factory reset, then include them again. If you need more details about how to do that, let me know. I’d need to know what version you’re running on your V2.
Mine are working okay. Today I’ve set the polling time from “0” to “blank” to see if they stay in sync better.
Has anyone tried including a VRCS4 or VRCS1 with full power?
Im trying and not having much luck…
My vera2 external battery is toast.
