Daniel and others read this message… Hello !
do you have documentation for: leviton VRCS2-MRZ ? because when I add it to vera3 the buttons in the wall stops runs…only access is by the vera3…and I think must runs in vera3 and in the buttons in the wall…
what can happens ???
another situation is : I click in shift controller in vera3…now, what this does ???
how can I reverse this ???
thanks…
Piwtorak
Can you please be a bit more specific about your issue? You say that once you add it to Vera3, the buttons on the scene controller are no longer working, but they are working directly from the Vera unit? I think you mean you’re manually activating the scenes from Vera, but this has nothing to do with the scene controller, if you manually run the scenes from the Dashboard.
Have you assigned each button to one of the scenes in Vera?
Controller shift tells Vera to transfer the role of primary controller to another Z-Wave controller. After you click 'Controller Shift,' proceed to add the other Z-Wave controller the same way you normally would
http://docs5.mios.com/doc.php?page=zwave_device_advanced
Hi Daniel,
if you search in the forum for: VRCS2-MRZ you can read a discussion about this device…
when vera3 added him the buttons in the wall do not function anymore…
I asked to Oti to explain step by step how can do work this device with vera3 and with buttons in the wall switch…
My another problem if you can help is how can I turn vera3 in primary controller again, because I pressed in controller shift button…what exactly this action does with vera3 ??? (press controller shift button)
thanks for your interest…
