Leviton VRCS1-1L Poblems
I cannot get this unit to execute any scene on my Vera 3. Anyone been successful with this device?
Which firmware version are you using?
Which brand/model devices were part of the scene?
oTi@ … after our long discussions is there a change in the ability to work??
The VRCS1 used to work; but appears broken with recent firmware. Looking at the Z-Wave communication from the device, it doesn’t look like any distinguishable on/off event gets sent to Vera. So it will only work with scene-capable gear, right now, I believe.
The VRCZ1 can still only be used as a toggle switch, unless you use the Leviton programmer. I think something in Vera can be done about this, but haven’t heard that it is actually being looked at.
k … tks.
