Leviton RZS15 Single Pull Light Switch
I’ve installed this switch and seems to work fine in both a 3way and single pull applications. I currently have it setup to control a single light in the house. I have control of this switch on the dashboard and can turn off and on and toggle the state via a scene. I would like this to work but don’t know how Set a schedule so that at 1030pm if on turn light off and if off just leave it off. I’ve been able to turn off (ToggleState) but if the light is all ready off it will just turn in on. Can somebody help me with this setup? Maybe I’m missing something simple but am unable to figure out.
[quote=“buck6919, post:1, topic:170500”]I’ve installed this switch and seems to work fine in both a 3way and single pull applications. I currently have it setup to control a single light in the house. I have control of this switch on the dashboard and can turn off and on and toggle the state via a scene. I would like this to work but don’t know how Set a schedule so that at 1030pm if on turn light off and if off just leave it off. I’ve been able to turn off (ToggleState) but if the light is all ready off it will just turn in on. Can somebody help me with this setup? Maybe I’m missing something simple but am unable to figure out.
Thanks[/quote]
Maybe I am missing something but wouldnt you just create a scene that has a schedule for 10:30pm turn light off?
Yes, you can schedule this to happen but when you select the option to toggle switch if it’s on it will turn it off but if it’s off then it turn it on. What I need to setup is a status check first then an action of turn off, if on or just leave alone if off.
Not sure why you need to do a toggle versus just off? (i.e. at 10:30 turn light off. If the light is on it goes off, if the light is off it goes off.)
OK I have my schedule set then I go to advanced and “just off” is not one of my options. I’ve enclosed my available options.
Ok that is the advanced tab…
Go to devices tab and select your device and click ‘off’. Then under the schedules tab create a new schedule for 22:30 everyday. You do NOT need to go to the advanced tab. I cant get to my Vera right now or I would cut you an image… Logged on to a friends…
Go to devices tab and select your device and click ‘off’. Then under the schedules tab create a new schedule for 22:30 everyday. You do NOT need to go to the advanced tab. I cant get to my Vera right now or I would cut you an image… Logged on to a friends…[/quote]
ALso what version of the UI are you running? I made an assumption since you are new you are running UI5.
U15 Vera3. I will have to get back to you because it seems like we are talking about something different. I might have to give you access to my Vera. I have device setup and can turn off and on no problem. If I create a scene and set schedule for 2230 I don’t see an option to just turn off device.
Its in the automation tab you see all your scenes. Click on the wrench icon on the scene and you get Devices Triggers Schedules LUUP Advanced. Devices is the default page to open to. There you see all your devices (most if not all are greyed out) Find the device you want to control and hit ‘off’. Click on schedules and create your schedule then hit ‘confirm changes’
Ah, OK that worked. I did know that thank you. I new I was missing something. Hope this helps other users.
