Leviton Light Switch Not Working as Trigger
Hello all. I have a Leviton dimmer switch (DZMX1) capable of instant status. When I use the Vera UI to turn off the switch, the scene works as desired. When I manually toggle the switch at the wall, the scene fails. I have it arranged the scene as follows:
Trigger: When Light A is turned off
Event: Turn off Light B
Both lights are the same Leviton model. The device wizard did not have a specific model for Leviton so I enrolled them as generic Z-wave devices and everything seems fine. Perhaps there is additional setup I need to do (i.e. tell the Vera the switch is instant status capable?). I am using Vera Edge with latest firmware 1.7.850.
Am I trying to perform a function that is not possible? If not, what am I overlooking. I’ve tried to search the forums for a related problem but the results generally include switches without instant status capability.
Any help would be appreciated. Thanks.
You are not alone here… I am just sorry I just found this post as I have been suffering with the same issue with a Leviton dimmer.
Historically it worked great as a trigger with a Vera2 with UI4, then upgrade to a Vera3 and UI5. When I entered the room and turned on the dimmer (light) my written scene executed and turned on a switched outlet too. The second scene also worked to turn it all off.
When I first got my VeraEdge I had my Vera3 slaved to the VE with both on UI7. The scenes would both trigger fine locally or using the Vera CP. Once I seemed happy and disconnected Vera3, the scene only executes from the Vera CP… just like yours!
Fast forward to the recent firmware update… it didn’t fix it. I still get a “Failed at: Please wait! Getting the manufacturer” notice and the same operational trouble. I called tech support and spoke to Brian. He says the switch is bad. I disagree as I explained it makes no sense especially given the history and timing of the “failure”.
I asked Brian to pass my case to George… that guy is a miracle worker and my only hope.
For now… no solution. I’ll keep you posted though!
Chuck
[quote=“YellowShark, post:1, topic:184532”]Hello all. I have a Leviton dimmer switch (DZMX1) capable of instant status.[/quote]There is the problem. The Leviton DZMX1-1LZ does NOT support instant status. The Vizia RF+ support Instant Status, the Decora line does NOT.
A skilled and enterprising forum member, @oti@, did figure out a hack to make Vera act as if the switch did support Instant Status IF it was communicating directly with Vera and not routed through intermediate nodes.
[quote=“Z-Waver, post:3, topic:184532”][quote=“YellowShark, post:1, topic:184532”]Hello all. I have a Leviton dimmer switch (DZMX1) capable of instant status.[/quote]There is the problem. The Leviton DZMX1-1LZ does NOT support instant status. The Vizia RF+ support Instant Status, the Decora line does NOT.
A skilled and enterprising forum member, @oti@, did figure out a hack to make Vera act as if the switch did support Instant Status IF it was communicating directly with Vera and not routed through intermediate nodes.[/quote]
My Leviton is the VRI06-1LZ Z-Wave 600-Watt 2-Wire Dimmer… should work I thought :frowning: .
The VRI06-1LZ does support Instant Status.
Contrary to your previous post, @chuck1026,you are not suffering the same issue as @YellowShark. Your issue is due to firmware bugs in UI7, his issue is that his device has no Instant Status capability.
[quote=“Z-Waver, post:5, topic:184532”]The VRI06-1LZ does support Instant Status.
Contrary to your previous post, @chuck1026,you are not suffering the same issue as @YellowShark. Your issue is due to firmware bugs in UI7, his issue is that his device has no Instant Status capability.[/quote]
Thanks for confirming that Z-Waver :slight_smile: . This bug is hard to kill! Well I hope George at tech support will help me out. I don’t see where we get case numbers anymore like the ole UI5 days so I can’t reference a case. Progress or ???.
Chuck
