No results in a search…
I got the GE dimmer installed and working yesterday (after dealing with a bad GE zwave on/of out of the box, GRRRR)
Now I have an issue with the lamps just “dropping out” at random when on at 100%. The two table lamps controlled by this new dimmer have (4) 8w LED’s from Home Depot. I’m not sure of the brand.
Is the problem, not enough wattage for the dimmer? Or is the dimmer defective?
I wanted a standard GE Z-Wave ON/OFF switch in this position, but the switch was bad out of the box, causing me hours of delay before I figured it out.
THANKS!!
Paul
