LED Strips
Wondering if I could extract the firmware from the controller I just ordered. Any ideas on that?
Not sure. Can anyone report that they have bulbs and strips in sync? May not be a reason to do it unless.
I agree, sounds like if changing controllers doesn’t fix it then changing only the controller firmware is also of no use.
Hey Everyone,
I purchased a Mi light led strip with wifi, I have set it up and can connect to it (the wifi hub) in the IOS app, before I can use in Vera i need to Link the remote.
I have tried powering and pressing the link button before 3 seconds ( that what the manual says) I cant get it to work through app. Works fine through remote that came with it.
Any help would be appreciated
[quote=“vas5150, post:64, topic:185698”]Hey Everyone,
Any help would be appreciated[/quote]
I don’t think you can link it to more then one device. For example I don’t think you can have the remote and the wifi setup. The wireless strip connects to one hub at a time if I remember right.
Thanks for the reply
so I am in australia and got it from a seller in China from ebay. They sent me an rgbw controller that is not a mi light controller and a rgb controller that IS a mi light controller. I hooked the rgbw strip to the rgb controller and i can control it, Just dont get the right colours. Have ordered another controller from another ebay seller!!
cheers
[quote=“vas5150, post:66, topic:185698”]Thanks for the reply
cheers[/quote]
Test out one color at a time to find out what you need to swap. I have found that the LED strips are not labeled right.
I have ordered the correct RGBW controller but for now I have set a scene for the colours I want, each scene is set to HUE… I went through and changed the hue number till i got the colours i needed, Also set a scene for disco mode.
actually does all i need for now.
