LED RGBW Control in the United States
So here in the US, I am stuck without the Fibaro RGBW LED controller I keep reading about in my searches.
I am in the process of starting an under-cabinet lighting project, and ideally I would like to use RGBW strips and a controller that can be set based on scenes from my Vera3.
I came across this “ColorPlus LinkUp” wifi connected set of products, however it doesn’t look like it would be an easy (at least to me) connection into mios.
http://www.environmentallights.com/14842-linkup-wifi.html
Anyone have experience with this product? Or have another tested idea on how to get RGBW control into Vera?
Thanks!
Fibaro say they will start sell in the US in November so maybe it will be better to wait I have 3 fibaro rgbw and this is great product
Sent from my HTC One X using Tapatalk 2
Check out this thread: http://forum.micasaverde.com/index.php/topic,14471.msg127912.html#msg127912. This system works quite well with Vera and you can integrate LED strip controllers (i.e. http://www.ebay.com/itm/2-4G-LED-RGB-Strip-Touch-Screen-Wireless-RF-Dimmable-Remote-Controller-12-24V-/190897097744?pt=US_Lighting_Parts_and_Accessories&hash=item2c725a8c10) with the wifi bridge. Also, Limitless/MiLight just released an RGB+W bulb.
I have pieced together components of this system and have been using them on my Vera for a few months. It’s not as versatile as the Philips system, but it costs half as much to implement.
[quote=“ntk”]Fibaro say they will start sell in the US in November so maybe it will be better to wait I have 3 fibaro rgbw and this is great product
Sent from my HTC One X using Tapatalk 2[/quote]
Fibaro has been saying they will start selling in the US for a long time now. I’ll believe it once I see retailers actually stocking the items.
  • Garrett
Exactly, they said August…then September…now November.
I am not holding my breath.
i don’t work at fibaro so i don’t know why this take long, but i’m sure they want to start selling even more than you want to buy, but sometimes thing take longer to approve and test than expected, they can say “when its ready” but at least they try to give an estimate
I’m not trying to defend them, I just know it does not always go as planned, which is why many companies wont give you an estimate at all and will say “when its ready”, I’m new here, but I’ve seen products from other companies presented already at CES that was supposed to be released months ago, from micasaverde, aeon labs and more
i can tell you that for now i have this products for my zwave network
5x fibaro wall plug
12x fibaro door/window x sensor
2x fibaro roller shutter modules
2x fibaro flood sensors
3x fibaro RGBW
3x fibaro 2x1.5kw modules
1x fibaro 3kw modules
2x aeon labs 4in1 sensor
1x everspring SP103 motion detector
1x vision shock and vibration sensor
3x dimmer switch TZ65S
and if they will release smoke detector this month i will buy 3 or 4 without event thinking
i really impressed with fibaro products, i think they offer a big value for the price and a lot of extra options to the main use of there products, if not the great community here, I would also buy the home center 2 without thinking at all, is more expensive than the VERA but I do not think you can compare between them at all, unfortunately micasaverde relies on the community to do the hard work for them, something as basic as changing the Icon interface is not possible (I know you can change the Icon to an entire group of devices, but not a single device and it’s complicated) there mobile app is a joke, I see the app of HC2 and know that micasaverde never do anything close to that, luckily there are amazing people here who do a great job and there is a lot of great apps for VERA like authomation and ImperiHome (and many more apps and plugins) and that’s why I chose VERA, the community of HC2 is still small, and this is another good reason to wait for them to release their products in the US, if the community of HC2 will grow, the VERA will have no advantage anymore
so in the end, i cant tell anyone what to do, i can only tell you that there product definitely worth the wait (at least for me) :wink:
