I have been searching the boards for a solution to control LED pixel lights with Vera.
Does any one have any ideas… I just don’t know where to start.
Should I go DMX and interface it with vera? What controller to use?
Thanks in advance.
Thanks in advance.
You’re talking about 12V or 24V LED strips? The Fibaro RGBW driver works a treat. You could use it for 4 separate single-colour strips.
DMX is for if you want to control each LED independently. If you are happy to have all LED’S controlled as one then the Fibaro is the simplest. You can also consider Sunricher.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
