[quote=“haworld, post:16, topic:183286”][quote=“wolverines, post:13, topic:183286”][quote=“haworld, post:11, topic:183286”]For multi-way circuits they ALL have to be designed to work together, in technology and for each model. If you buy one Linear Z-wave master, then you need one Linear Z-Wave slave for a 3-way. Using GE? One GE Z-Wave slave requires 2 GE Z-Wave slaves for a 4-way. Also you have to check the switches instructions to make sure you buy the right companion or slave for that model switch.
HA switches are different from the old standard style 3-way switches, they were a different switch with 3 poles and you installed multiples of them, the difference in circuits being done by the number of wires, these HA switches all are single pole (2-way) AND are also multi-way masters. So you always just need the one master for each circuit, then add the correct number of slaves that works with that master for however many number of switch locations you want.
Hope I explained this clearly, for you case, a 6-way circuit (which I have never done or seen before, the GE/Jasco cannot do that many actually) you would need 1 Linear Dimmer/Relay as the master and then associate 4 linear WT00Z-1’s to that one master. Leviton can do it as well with different models. Or you could use a scene controller but you need one that has a local load.
Hope thats clear, clear as mud? lol[/quote]
thanks. It looks thoroughly confusing! JK. I’m going to leave that hallway until later but at least I now know that 3-way switches are not typical. I have neutrals everywhere so I should be set when ready. I’d rather stick to some standard switches (like front porch) and get something right and working. Been reading up on the various brands of switches. Lutron, Insteon, Leviton and Ge/Jasco seem to be the most popular (in no specific order). Lutron sounds rock solid but the expense/learning curve probably rules it out. Insteon might be the leader of the pack. Still reading up on everything. Will likely try 1 switch and bulb, make sure it’s working and if we like it move forward from there. Trying to take advantage of the fact that everything is wide open and I have no switches or lights/trim kits yet![/quote]
Remember all those brands you mentioned are each different HA protocols so Vera doesn’t support all of them out of the box as its natively zwave. Insteon requires a modem to work with vera, Leviton makes zwave devices as long as you get their z-wave line of Vizia RF, similar to Ge/Jasco, they both make non-zwave switches. I am not sure but I don’t think vera will work with Lutron without a separate bridge, the new one they just came out with.[/quote]
Just a side note to this. Leviton now sells a line of z-wave items that are NOT part of their Vizia RF+ line. For instance, here is their non-Vizia RF Z-wave dimmer (listed as just “Decora Z-wave”)
http://www.amazon.com/Leviton-DZMX1-1LZ-Controls-Capable-Universal/dp/B00LEWQY6C/ref=sr_1_8?ie=UTF8&qid=1412462780&sr=8-8&keywords=leviton+z-wave
