LED Indicator Light On Switch
I recently installed a number of GE/Jasco on/off switches model 45609. After a few days the LED indicator light has stopped working on one of the switches. All other functionality of the switch works fine, both at the switch and within Vera. I checked the parameter using UI5 that controls the LED indicator at the switch and it is set correctly so that the LED should light up when the switch is turned off. I also turned the breaker on and off hoping it might get the LED functioning properly again.
Has anyone experienced a similar issue with the LED indicator light on one of these switches?
This has not happened to me, but it sounds like the LED bulb is busted?
