LED bulbs starts to flicker when I turn off the light
reply 12 : no, its a load not a bypass. between O and Sx…
reply 19 : at what point you did not understand the practical reality of this stuff ? load = 25W light=5W there is nothing a halogenbulb will change this.
Hi all,
Thanks all for your support! I used the 3 wire setup including the bypass. No flickering anymore!
Cheers,
Jasper
good to hear you have solved it
If you require any help dont hesitate to ask :slight_smile:
3-wire is the best setup.
yup, 2-wire only gives troubles and undesired effects allthough its a nice feature.
