I got 2 Sq in my house! one of them works like heaven!
the other…
i did the following
updated firmware to P100 OK
add to my network OK
Connected in SQ remote HD OK
when i use the SAMSUNG TV codes that ive added in the other SQ blaster, doesnt work when i use the TV Samsung codes from Sq remote, works!!! When i ask to learn, the RED LED lights up in the SQ Blaster, but nothing Happens when i press te remotes buttons!
Learning Failed!!
conrado,
have sure you are working with the correct blaster.
each blaster will have your own devices… (I think square connect could be include a option to import the devices, macros and codes from another sqblaster to help a set up equal devices in different rooms).
[quote=“Piwtorak, post:2, topic:176668”]conrado,
each blaster will have your own devices… (I think square connect could be include a option to import the devices, macros and codes from another sqblaster to help a set up equal devices in different rooms).[/quote]
Yep, got the SQ-1b6b, and the 17d9(the one that its not working)
the SQ-1b6b
has: Samsumg tv, logitech, cable tv, DVD, etc…
when you select Samsung Device for an example, there is an option: wich blaster!
this way you can import from one SQ Blaster to another!
But the SQ-17d9, doesnt learn the IR codes from the remotes when i set up a new TV (LG)
not eaven send a blaster signal, from the OLD Samsung tv,
but when i load the Samsung Tv back to the SQ-1b6b
works fine!
added Samsung tv, (to test on my samsung tv) works ok with the codes from SQ REMOTE
but when i add a new device
LG TV, doenst learn the codes!!! LED light inside Sq Blaster its ON,
but i cant get it to learn!
I can’t get mine to learn either. I have a Harman/Kardon HD990 CD player - no codes available in the SQ database for this device. And I can’t get the SQ Blaster + to learn from the remote. I have updated the firmware & reset the device. Now very annoyed. Any thoughts?
Still not working!!
Tried updating the firmware again, reinstall the network, nothig!!
The only codes thar work are the one in Sq Data Base( like Samsung tv) but it wont learn!!!
If anyone know how to solve this, please email me!
