Launch Authomation right into Favorites screen?
Is it possible to show the favorites screen at startup of the app?
Which version are you running? Are you running AutHomation or AutHomationHD? Is it the version from the play market or the beta currently offered in the forum? The current beta allows for setting the default view.
  • Garrett
Yes, you can specify this under settings from within the app!
It has been so long since I used the release version in the market and so much has changed from the release version and the beta. I believe this is also available in the release version as well. Pretty said coming from the developer.
  • Garrett
Sorry to not follwo up on this, I downloaded the beta, and found it in the settings! Thanks
