I have a similar issue. Problems started yesterday, with my schedules not triggering properly, and this morning I get a ‘wait bar’ Isee attached image) when trying to open inputs, conditions, and actions. The latter started, I think, when I enabled debug. The schedule problems started yesterday (anything related to the switch to summer time?).
Same here. Program Logic Event Generator is (downgraded?) at 5.93. UI stuck on loading if I try to change any of Inputs, Conditions, Actions. (For example when clicking Inputs it stuck on: “Opening pleg_Inputs…”) Also, can not get Status report. I tried to update the plugin with http://myhost:3480/data_request?id=update_plugin&Plugin=3066 with no sucess.
Similar issue for me. Core is at 6.4. PLEG (downgraded automatically) at 5.93. I haven’t registered for a paid version yet (but will probably do so soon, when I plan to make more use of it).
UPDATE: Since my post earlier today, Vera updated itself automatically to 6.5 and all is seems to be working. Thanks Richard.
I see this in the logs during a (frantic) reboot:
03 03/31/14 7:21:32.072 UserData::LoadUserData BuildVersion: 1.5.622 SvnVersion: 7546 Model: 31 Sercomm NA900 flush: 0 changed: 0
02 03/31/14 7:21:32.219 ^[[33;1mJobHandler_LuaUPnP::FetchMissingFiles need to download J_ProgramLogicEG.js^[[0m <0x2af9f000>
02 03/31/14 7:21:32.220 ^[[33;1mJobHandler_LuaUPnP::m_sMissingFile_set J_ProgramLogicEG.js^[[0m <0x2af9f000>
My Apps Tab also looks funny:
PLTS: 6.2
PLC: 6.4
PLEG: 5.93
I have the same issues. I can’t see any inputs/conditions/actions due to the “waiting” screen, and I can’t get a report or status. Versions are 6.4/6.2/5.93 as reported above. The only real aggravating part about this is that now I’ve paid for this app. You expect things to happen, of course, and I think we’re right around the license transition date which could explain some of this… but when I pay for something, my expectations increase a bit.
[quote=“dawiinci, post:9, topic:180475”]Same happened here. Doesn’t work anymore with paid license.
Also I have constant reboots - might be related to this as well…
Not happy about this.
EDIT:
Fixed it by unchecking Auto-Update and rechecking it - SAVE and you are on 6.5.
However this shouldn’t have happened![/quote]
Constant reboots here, too.
I unchecked auto-update on all three apps, saved, then re-checked auto-update & saved… but I’m still on the same versions as I posted above.
Sorry folks …
I released a version 6.5 yesterday … I am only allowed to have three versions (two existing and a proposed 3rd on the App store).
When I release a new version I must pick one to delete … I picked the wrong one for PLEG … and deleted the previously most current release. There is NO undo command!
Until the 6.5 get’s accepted the OLD one is the 5.9X is the only currently consistent version (for PLEG/PLTS/PLC)
You should be able to restore your system with the most recent backup (if you want to stay on your previous version) or upgrade to move up to 6.5 … MCV just approved that version.
