Latest Update - Breaks Pleg?
I have just performed the latest update on my Vera Edge
You are running the latest version: 1.7.1419
Pleg is now unable to see any devices in Vera.
Anyone else had this issue?
I took the plug and bought 2 licences yesterday and set everything up, now all my INPUTS are missing from my PLEG devices
Any ideas or suggestions?
N
Hi alpha1
I have exactly the same problem.
I upgraded the firmware om the Vera yesterday evening.
After that i did some programming om a new PLEG and everything seemd to work fine.
This morning i wanted to continue creating my new PLEG and the input editor for Trigers, schedules and counters dont work anymore.
The input editor for “device Properties” seems to work, because there i can see all my devices.
I restarted the Vera controller serveral times but that does’nt work
I have’nt reset to an earlier update yet, because i do’nt know how to do that.
I havo no idea what to do now
I hope someone can help
Richard who crwted and maintains pleg has raised a support ticket
http://forum.micasaverde.com/index.php?topic=33741
Hopefully they respond to him soon
Same issue here - all of my devices have vanished. I haven’t updated Vera, but do have apps on auto-update.
Your problem is you need to update vera if your apps updated.
Vera update broke PLEG and Vera Alerts, richard created an update of each to fix what was broken in the vera update.
Problem is the new PLEG and Vera Alert updates don’t work with old VERA software. So if you update or it auto updated your plugins and you on the old vera you have a problem.
If you updated vera but didn’t update plugins then you have problem.
Only fix is to roll back to a saved point in history before the plugins got updated or update Vera to match the new plugins. Can’t have mix and match.
