Kwikset SetPin Settings??
I’m trying to set a Pin on a schedule but it doesn’t seem to be working…
When configuring the SetPin function in Advanced for the scene I see:
Here are the entries the UI is looking for:
json (No idea what to put here…which is probably why it doesn’t work!!!)
UserCodeName (I gave this my user’s first name)
newPin (this is the pin I want to set)
Can someone tell me what I should set for JSON…and am I doing this correctly?
I finally got this to work tonight!!
I added the following to the LUUP section of SetPin in my scene:
“user_code” : {
“slot” : “3”, //slot to put pin in…use this for ClearPin as well!
“name” : “Tom”, //name of user for pin
“code” : “121212” //actual pin code
