I have cleaners come every 4 weeks on Friday. Am I able to schedule a recurring PIN code that works only on those days? I only see a daily and weekly choice. TIA.
Short of writing code, I think the best you can do is to chose “Weekly” under the drop down box and then limit access on Fridays between certain times of the day.
Or, under the “Daily” drop down, you could select the valid day, i.e. 08-31-2012 (a Friday). The problem is you can only select one valid day, so not excatly automatic.
Lonestar10, thank you! I’ll investigate the code option as time allows…
