Kwikset Lock (lock at night and unlock in the morning)
Hi folks,
I had the autolock set on our garage entry door but I’m looking for a more elegant solution to lock my door ‘automagically’ in the evening and unlock it in the morning. I have been unsuccessful in getting my Vera3 configured to get this working and would ask the very smart folks here to give me a nudge in the right direction…
Here’s what I’ve done so far:
  1. Downloaded PLEG App
  2. Download Day or Night App
    Day or Night
  • I have set Day to +02:00:00 relative to sunrise
  • I have set Night to +01:00:00 relative to sunset
    PLEG
    Inputs - Set Device Day or Night to event type Day or Night has arrived
  • Named trigger Sunrise to indicate daytime
  • Name trigger Sunset to indicate night time
    Conditions:
  • Add condition AUTOLOCK with expression ‘Sunset’ (no quotes)
  • Add condition AUTOUNLOCK with expression ‘Sunrise’ (no quotes)
    Actions:
  • Add Autolock 1
  • Add AutoUnlock 1
I have created a scene named ‘Night’ to run and lock the door but can’t figure out how to create the trigger to get things going. I’m also not confident that above steps were created correctly to begin with. I checked a few other relevant threads but I can’t make sense of the condition statements (which I thought were replaced by use of the Day or Night app) and the instructions relative to setting the scene to activate.
Any help given would be most appreciated.
Brent
You do not need a scene … Because the Actions will lock and unlock the specified lock.
Have you Armed the PLEG ?
Actions will not fire if you do not arm the PLEG.
You should be able to lock/unlock your lock just by manually changing the Day or Night switch.
Send the output of the Status command from the Control tab of the PLEG if you continue to have problems.
Holy cow… its works! Clicked the Day or Night app to night and it locks… Click day and it unlocks. Woo-Hoo!!
Nice to know that I was smarter than I thought (except for the checking my work part)… Now if I could just figure out that ‘smarter than I look’ part… ;D
Thanks for the help!
