Kwikset 914 PIN issues with UI7
I recently upgraded my Vera2 (UI5) to VeraSecure (UI7) and decided to start from scratch vs. migrating the configurations/backup. I have a Kwikset 914 that has been working great with UI5 for several years. The lock is fully visible and controllable (lock/unlock) from the UI7 web interface. I can also control the lock through the iphone app. I used the master code to delete all existing PINs after pairing/including in the new system
Here are my issues:
[ol][li]I can add PIN codes in the web interface, but they are not displayed (Devices/PIN Codes). Show PINs in Clear is checked.[/li]
[li]Since they don’t show up on the web interface, I cannot delete PINs[/li]
[li]I do not have an option to enter date/time restrictions on PIN codes. This system is at a vacation/rental house where I need to be able to enter similar restrictions that were available in UI5.[/li][/ol]
Any ideas?
I also checked the KeepPinCodes variable in both the old (UI5) and new (UI7) system. It is was set to 1 in old and 0 in new. I set it to 1 in the new system and entered a test PIN. UI7 gui will still not display the PIN codes.
Also, in the old version, there is an option to “Keep a copy of my PIN codes so that I can view them later” in the gui. I do not see this option in the new system.
Help…
